Transportation Research Board (National Cooperative Highway Research Program) 2010
Roundabouts: An Informational Guide (2nd Edition) PDF (21.6 MB)
Mike: I haven’t read this yet, but my experience on the Vineyard, where
a roundabout solved a longtime traffic problem, at least for the autos,
tells me the following: 1) roundabouts are great if they replace stop
signs or lights in an intersection with /only two roads crossing at
right angles*/; 2) It can still be treacherous for a bike to negotiate
even such a modest roundabout; 3) roundabouts are horrible when four or
five lanes of traffic descend on it and must funnel into it; witness the
roundabout south of Route 9 with Hammond Street, Hammond Pond Pkwy,
Brookline Street and two other thoroughfares all converging.
Be well and stay safe.
Bob Jampol
** the junction of Edgartown-Vineyard Haven Road and Airport-Barnes Road.**
Hi Bob,
Thanks for your comments. This voluminous guide and other information is helpful to add context to issues you raise. Some thoughts:
Hi Bob.
As Mike points out, while the terms are used interchangeably, roundabouts and rotaries are traditionally two very different things. Rotaries typically imply much larger circle radii and higher speeds, built more like highway interchanges, often with necessary lane changes. Most of the old traffic circles along VFW and other MDC and State roads fit that pattern. By contrast, modern “roundabouts” use a much smaller circle and a tighter inflection angle entering the roundabout which drastically reduces speed. We don’t have many good examples around here. The best ones are on private developments: Ikea in Stoughton and at the Natick Mall. Horace James Circle (Hammond Pond Parkway) is one of the worst kinds of rotaries, modified to be a bit more roundabout-like several years ago, but it still has very troublesome geometry. I’m very concerned that people will immediately compare the Auburn Street proposal with the notorious “bad” rotaries around here, since that’s what people have known for so many years. That’s going to be a challenge.
Safety is improved by roundabouts because vehicle conflicts are reduced, especially the most dangerous types: right angles (think t-bones) And best of all, there are no left turns! There are also dutch designs for roundabouts with separated bike lanes, but they take up a lot more space than we usually have around here.
